mik667
- San Francisco, Ca
hey all
Well i have assembled the SF, and for about 15 minutes it ran sweet - best acceleration I've felt in it - yeah! then it went on only 1 cylinder, figured it fouled a plug, new plug and it ran for about 1 minute and then quit on that cylinder again! shit! then again, and again w/ different type plugs etc - some times only 20 seconds or so before the same cylinder quit... i can pull the plug from dead side and place in the other side and it fires right up on that cylinder(!) - yikes
Checked the compression 180 lbs both sides (!) - I've tried changing the coils (w/ new ones) - same results, new spark plug wires & doubled checked the floats - (same results) - ran squiter fluid through ever orifice on the carb and it still does it - finally i am suspecting the Sachese EI - i have noticed that it if i go to short out the sparkplug cap/terminal on the offending side (i have some old school hot rod spark plug caps on it temporarily to help me figure the problem out that have the tip of the sparkplug exposed - they clip on the sides of the plug its-self) there is no/weak spark that will arc between a screw driver placed on the sparkplug and the barrel making me suspect the spark on that side is running only part time - on the opposite side (thats running nicely) when i do this a big arc goes between the screwdriver and the barrel and the bike dies. I've rechecked all the connections, removed them and replaced them in the control box etc w/ no cure.
I have noticed if i set the sachese to just "fire both plugs" by dialing "0" i get a big arc w/ screw driver on both plugs (and nice spark if plugs pulled out )
anyone had a failure like this - or other suggestions to look at? driving me friggen crazy
thx as always! Mike
thx as always! Mike
