steppenwolf
- france
hi there, does anybody have a "spec" for swinging arm play? on my sf1 it's 1 mm at wheel spindle, how does it sounds? thanks
steppenwolf said:thank you all for valuable advises. here what i'll do :
1. remove lower shock mounts and attempt to measure free play again
2. generously grease (i think i have bronze bushes fitted).
3. re-check
4. hope for the best...
new question: considering free play would be bound by both wear at bushes - axle interface and bushes - frame fixing points, would you think that shimming here (i.e. between bushes and frame) would help recovery (part of) free play? thanks again
sfcpiet said:No.
Axial play is rarely an issue as the axle and bushes are normally the correct length and should fit into the frame snugly. Should the bearing face of the bush to the frame be excessively worn, it is bound to be knackered radially as well...
Most wear occurs between axle and bush, you could cut a Coke can in strips and insert that, I've seen that a few times!:
