SF3 clutch lever
macavity99
Bedfordshire, UK
My SF3 has the original (Tommaselli?) clutch perch with choke lever and polished alloy clutch lever.
Anyone know of a black dogleg clutch lever drop-in (or easily modifiable) replacement for my existing clutch lever? There are some Tommaselli levers on the Gutsibits website, but I don't know the part number to choose.
Thanks
Steve C in UK
Unless you plan on not stopping on your SF3, I think you are barking up the wrong tree. A dog leg on the standard perch will give you less clutch movement than you have now.
Has your left hand shrunk?
Hi Steve, I use the clutch perch of the Guzzi Daytona/1100 Sport on my 1200SC - it is a real improvement:
https://www.ebay.at/itm/MOTO-GUZZI-Kupplungshebel-kompl-Daytona-1100-Sport-/162285625415?hash=item25c8fa2047
But you will have troubles mounting the choke.
Very difficult to find a dog leg lever which fits to the original perch.
Ciao, Gert
I use an Aprilia purch and dogleg lever on my cable clutch Pantah, that easys the pull considerably and takes the usually bigger nipple. About $60 from Gowanlochs and used on there Pantah race bike.Wish I could afford there 2into 1 race bike exhaust,its a stunner
I installed a Kawasaki Z (several models) perch on my SF in the 70s - wide support and easy to get different profile levers for. Also has the insert for a mirror or a small bracket to accommodate the orig choke lever assy. I used a black dogleg clutch lever, which matched the one on my Brembo Goldline m/cyl. Had to drill out the clutch nipple hole - easy peasy.
If you're counting rivets, ignore all of the above.
Ducati dealers don't have the other Laverda parts. Neither does eBay/Amazon/Cheap-Chinese-Imports. Support your local dealer whoever that may be.
There is a Laverda dealer near to every major country and can ship anywhere in the world. We all buy from the same manufacturers and can stock the same product. A few of us manufacture and stock specialist parts to suit your Laverda and can order in most things if it is a good item to suit Laverda.
If you need a specific a specific item https://damclassicracing.com.au/contact-us/
https://damclassicracing.com.au/60413069-1-magura-clutch-perch-lever-116940/
https://damclassicracing.com.au/60413941-clutch-perch-and-lever-w-easy-adjuster-941/
https://damclassicracing.com.au/60413070-clutch-perch-lever-holder-tommaselli/
https://damclassicracing.com.au/60413942-clutch-perch-and-lever-w-easy-adjuster-31112-01/
