SF750 Cylinder Head feature
  • Thread starter Thread starter lavfancier
  • Start date Start date
L
lavfancier
Guest
One more question folks:
Any thouights on the purpose of this feature on the cylinder head around the studs- looks like its been purposfully done but not particularly consistant with the recess nearest the camera being twice a s deep as the ones at the far side.
Once again your experience and advise very welcome.
LF
Hello, LF.
These marks around the studs are traces of a bad job done.
Seems like some dpo tightened the head down to close
a tight camchain and used some sharp-edged tubes as
distances-holders without washers.
Ernesto
Fuckwit DPO used sockets as spacers to tighten down the head as Ernsto has suggested...
Yes, you could say it was done on purpose. ::)  Problem is, it will reduce/interrupt oil flow to the rockers in no small degree.  You will need to fill the grooves up in some way or another.
OK thanks for that- just needed to make sure there wasn't something a little more subtle going on.
Best find myself a good ally welder then!
LF
