I've taken the primary cover off my SFC 1000 to replace a couple of oil seals, and to have a look and see if I can see anything untoward in there.
Just over the last couple of hundred K's or so I've noticed a noise coming from near the front of the primary cover so I thought it was worth a look to see if there's anything obvious. The noise - well hard to describe really, a slightly high pitched whirr or squeal maybe............??? (dunno). Sounds like primary chain, I know.
Anyway the primary chain is fairly new, as is the clutch basket and rubbers, they've all got about 5 - 6000 k's on them. I think the Primary chain is adjusted ok - take it to about 3000rpm, adjust until it squeals then back it off? Can't say that this method actually gives me alot of confidence though!
So I was thinking the oil pump maybe? Last time I checked there was still plenty of oil getting thrown up to the top of the motor (probably would have seized by now if it hadn't been!!!).
The question is, should I just go ahead and replace the oil pump anyway as it doesn't look too difficult - or is it fraught with danger.............or should I just leave the pump, close it up and try adjusting the chain again?
Any thoughts?
Keith.
Any thoughts?
Keith.
