Wise men..
I'm about to replace the camchain on my SFC1000 at 100,000km.
Valve clearances reasonable by my measure (one exhaust clearance a bit tight at .0085"). Have the good new Iwis chain.
Been a fair while since I did the camchain on this bike (50,000 was some time back). 180deg engine is easy. I cant recall how I fed the chain in last time on this bike.
Dont want to have to remove one or both cams so they dont clash with pistons. Dropping off the cam guide thing in the sump seems a bit unnecessary (but might be simplest of the three choices). Feeding in the new chain hooked onto the old one while rotating the crank and cams in sync to avoid clashing valves with pistons seems painful.
Advice please??
Thanks,
Andre
Advice please??
Thanks,
Andre
