Side cover packer
Vince
I recently broke a plastic side cover,not happy. So the replacement carbon Bobba joby has no front peg so its a bit hard to estimate what packer is needed to bring it out to the std amount with a peg. Anyone got a dimension for this packing off the frame mount the bolt goes through to  the back of the sidecover..
Vince I have a standard rubber grommet in the front lug and then turn the screw in till its tightish... keeps the cover in the kind of right spot and the tension of the rubber pushing back stops it from coming loose.
Want me to bring two of my patented cover screws and plastic washers... ( stolen from an RGS )
Speaking of stolen from an RGS have sorted my handle for pulling the Cico onto the centre stand. Who would have thought it would have been a bolt on fit... hole distances spot on... go figure...
No I have the bolt setup sorted. Thanks anyway. I need to pack out to clear the pod air filters anyway,its going to be 15mm or so I expect
quick cheap and effective.... I use a length of rubber hose over the fastener as a spacer, cut it longer than necessary and then tighten until it compresses to the needed length.
Paul LeClair
Dont worry about Vince I made him some nylon jobbies turned em up in the lathe he ended up needing then at 3/4 inch..........
Vince said:
Dont tell Brett but I cut 4mm off the thickness with my trusty Sandvik Hacksaw.
Ok I wont talk to myself about it. Should have went with your first guess could have save me near half and inch of the nylon rod I turned them up out of....
