Side decals
Erm.......?
Superglue?
Strong, quick and if you need to remove the badges, all that happens is the glue takes the paint off where you can't see it...
Simples......
I recently used a double sided tape,Red tint,that at first use I thought I had single sided cellophane tape by mistake.It was extremely thin.Virtual invisible without a very close look.
Toolstation VHB double sided for ?20 a roll or 3M 467MP works well.
The 467MP is an acrylic adhesive and gives a flexible bond on plastics while resisting heat
unlike rubber adhesives which seem super sticky then dry out and fall off.
Make sure you degrease both surfaces with alcohol or lighter fluid before bonding.
I  use 467MP regularly for protected graphic labels and it has been very reliable.
One use is petrol pump grade labels typically applied to fibreglass mouldings and given
the heat expansion, fuel splash and mechanical wear they survive very well.
