Its possible in the case of Laverdas to fit one seal and the mud scraper below the circlip BUT you need to modify the mud scraper so it will fit by grinding it down in size. I then added the black rubber cap as well. These green gadgets are steel encased in plastic. Its tedious but doable. Maybe your application won't need this or you make a spacer and only use the seal. I tend to go nuts and do all I can, overkill but that's me. BTW this full system is fantastic, seals very well but reduces stiction by lots.
