angonemoto
- Chicago, USA
Hi all,
Just did an oil change getting ready for the season and I noticed the speedo gear drive housing had rotated to the point where the cable is pulled nearly taught when the bike is static. When I sit on it the sag reduces the amount of tension in the cable and it looks ok. The black vinyl cable protection has cracked near the housing exit so I am thinking of taking the tension off and thinking of a shrink tubing fix to keep water and grime out of the cable itself down there.
What is the correct way to rotate this housing and to what degree do I need to rotate it? Is there a detent or something that we missed at the last tire change? I imagine I just loosen the axle and rotate it back, right?
Thanks
Bob
Thanks
Bob
