I bought one of these a couple of years ago, they were on special for $100 or so and were the big new thing for off road bikes. The last couple of rides I have found my 3C to be a bit unstable in a straight line, not horrible but noticeable. I put it down at first to low air pressure in the front, I got slack and didnt check as I usually do ever ride.
Tried 37psi and it was better, from 34. Next trip and its back to a bit loose. Put it down to a worn out front tyre and have one coming. But I have been concerned about the left side of my rear wheel spokes not ringing with a tap. Right side does but the left was pretty clunky. So I thought I would give the spoke torque wrench a go. You need to be a bit circumspect using them. You just cannot go and bang away at it.There used to give an indication as to how even you get the tension. I first went around the wheel both sides checking to see what torque was needed to get them moving. The recommended torque is around 5nm, what I found was all the right side was at 5 but the left was 3.
The rim has no discernible run out in both plains so I slowly went around upping the left to 4 and then 5. Giving the rim a check as I went. In the end I now have a similar pinging note from both sides and similar torque values. It's all got to help with the handling, will keep and eye on rim alinement and spoke tension and see what effect this has. All in all, I like this gadget, yes you can get by with just tapping the spokes but this works to get even tension as well.
