SandPebbles
- Madison, CT U.S.A.
Yesterday I turned my attention to overhauling the starter clutch on my '74 3C as I get this bike back together ever
so slowly. While I found a few springs broken, I also encountered two pegs that were stuck in their bores. One finally
came out with a combination of lubricant, gentle tapping and prodding the top of the peg. The spring behind this peg
was naturally broken. The second peg has become more of a challenge. It will not budge. It does rock back in forth in
bore (think a worn piston rocking in cylinder). I tried a little local heat with no success. I have read at least two
forum members have encounter this problem. Any tricks or insights to solve this problem would be appreciated.
Next question involves the thin metal cover over the starter clutch. Mine is still riveted on. I believe it was Reggie3cl
who has found this item in pieces upon opening the cover. Is it common practice to drill out the rivets and replace with
nuts and bolts? Tap the hole and use a screw? Suggestions on hardware to use?
The rivets for my starter clutch cover do appear to be tight...
