Starter idler gear
The idler gears are different, the larger gear is the same as both starters will fit it, but the drive to the freewheel has a different tooth count.
MkI part # 41 119 064, MkII # 41 119 189
Piet is the Sprag clutch unit the same for both series one and series 2. I'm getting confused now..but then that isn't too difficult these days lol
Not the same Joe.
MkI unit has 8mm rollers, MkII has 10mm with differing freewheel diameters.
Quite strange really, the early type rarely gives problems whereas the later is full of them!
