Spondonrider
- Colorado
I have a couple of bad starter motors here, one on the bench and one in my Spondon framed bike. Both have bad spots that the motor wont operate from but if I rotate the motor a slight bit then it works fine, until it stops on that bad spot again. I have dissembled the one loose motor and other than dirt it looks ok. Is this "bad spot" caused by a dirty commutator? I've cleaned it with a scotch brite pad and it looks pretty good. How about the brushes? They look ok to me, just worn to fit the commutator but plenty of brush left and good spring tension. What do you all think?
