Stripped thread in primary cover - RGS
Chappo
Hello all, I have stripped the thread in the primary cover on my RGS, where the primary chain tensioner bolt goes. When I took the bolt out, one turn of thread was on it. I thought that doesn't look good, and when I put it back, most of the remaining thread came away.
What would be my best option for repair? A Timesert? There is a place close to me that is a distributor for Timeserts, if I took the bolt to them, I expect they would be able to determine the pitch of the thread and sort me out with a kit.
I've fitted helicoils before, and there are links to instruction videos on the distributors website for fitting Timeserts, so I feel confident enough to have a crack at it myself.
Other than trying to buy another primary cover, what other option do I have?
Any advice and tips would be appreciated.
Thanks.
  Timeserts or helicoils should do OK although thread isn't as deep as i'd like. A bespoke flanged bush of maybe 14mm fine thread by the 10*1.5mm thread that the adjuster is may be a better option. New chaincase is not cheap! - Regards - Phil
Thanks.
Best Option is;
Take the cover off send it to Red and get him to sort it ....that way you know it will be spot on !
To get a helicoil kit ( yuk I hate them ) would be cheaper than a time sert kit but still hard to find either the correct length so you would have to bugger around.
Or if you are stuck then PM me and maybe I can pick it up as am up that way next Monday then will sort it for ya
Thanks Phil and Brett.
I've had a look at the Cross Tools website (the Timesert distributor near me) and they have quite a few different depth kits for M10 x 1.5. They list: 9.4, 11.0, 14.0, 20.0, 22.0, 24.5, 30.0 and 40.0.
http://www.crosstools.com.au/time-sert-thread-repair---helicoil-alternative.html#mfrsspecial
I haven't taken the cover off yet, to measure the depth of the hole, but I reckon one of the above lengths will do the job.
I just watched this video, and it seems fairly straight forward.
http://www.crosstools.com.au/video---how-a-time-sert-works---how-you-install-one.html
It seems having a brass bush/insert made up and threaded in (is that what you mean Phil?) would be similar to a Timesert. Are there any advantages over using a brass insert to a Timesert?
The motor has been out of the frame for about four weeks, the frame is away having the head stock mod/repair done. I drained the oil and removed the adjuster bolt, before I removed the motor, because it looked like it would be easier to lift the motor across onto a stand with the adjuster bolt out.
Last night, I decided to put oil back in while waiting for the frame to come back (it's taking longer than I thought) so I could turn it over, to keep things lubed.
Now I have this problem to sort out before I can get some oil back in it.
The problem with fitting a larger flanged threaded bush is that the lock nut will most probably be tightened against it.  When un-doing the lock nut, you risk loosening the bush.  Even if the bush is Loctited in place, care would be required if the lock nut is to be disturbed on a warm motor.  Loctite loses its locking properties with heat.  A bolt won't un-thread itself, but it is quite easy to break the adhesion and remove when hot.
A slender Timesert insert fits beneath the case surface, the lock nut is tightened against the case proper, no danger of having the insert coming loose.
Which ever way you choose to go please make sure that you keep the tap straight and parallel to the original threads.
Oh and good luck with it.
  Yes but no cost if you have the facilities - can use any metal -  done a few in mild or stainless steel - never had one turn itself out - always Loctite them after a thorough de-grease. - My own own one in my 750 I did in 1986 and it's still there! - Regards - Phil
After weighing up finding someone local, or sending the part away for repair, against buying a Time Sert kit from eBay for $145.13 (AUD, delivered), I went with the eBay option. It took about one week for the kit to get here from the US.
The hole depth is 16mm, so a standard 14mm Time Sert kit was the go. (The next size up insert is 20mm).
I set up my Black and Decker milling machine. I put the bolt in the hole to give me a look at getting the hole upright.
The drill did not go through cleanly, it kept snagging. I started off with a slow drill speed, tried a bit faster, but still it kept catching. After it caught about four or five times, I was through.
The counter boring and tapping was straight forward, and putting in the insert.
The hardest part of the job was running a die along the bolt, to clean the thread up. It got real tight about a third of the way along. I had to lock a couple of nuts on, and work it back and forth a lot to get it through.
It is all good now, and I don?t have any oil leaks? so far.
