Try putting a 460ohm resistor across the terminals on the blinkers. This, along with the LED bulb, will draw enough current to activate the flasher.
I have a different problem. I love LEDs, especially for tail light applications since they tend to last much longer than incandescent bulbs, but I cannot get one to light on my SFC. Since there is no flasher to deal with, this should be a simple change the bulb proposition, but for some reason, while an incandescent bulb works find, the LED replacement does not. The difference in current draw should have no effect, so this is perplexing....anyone else have this problem?
