Yes, tend to put the powder into the area and drip the superglue into it.
The thin model maker stuff works best for penetration and a bit of moist breath speeds the cure.
Gives a crystaline sort of structure but doesn't really flex much so not so great on very flexy plastics.
I've repaired cracks around mounting lugs on ABS type bodywork and smoothed internal radii around stress points.
The fuel filler flap hinge pivots on my motorised sofa were repaired as a temporary fix 2 years ago and are still fine.
you would think if one is to put it up on you tube that you would make sure that the camera was set up properly instead of showing his hands.
Not really a new idea just someone's take on Pratley's powda bond........been using that shit for years a real arse saver
