swingarm pivot bracing
twinweb
oz
anybody got a piccy of bracing round the swingarm pivot so i can show the frame guy-i know what i want -but easier to show him than explain it
cheers paul
hey thanks mark-sorry i missed your call yesterday-i was wanting a piccy with the standard footpeg mount-dont want to remove that at this stage
cheers paul c
The bracing on POP is a double skin in the pivot area, copying that used on the SFC 750.
It allows the standard footpegs to be used, but you need a wider spindle, which coincidentally is the same width as one for an SFC 750.
The SFC one is 16mm diameter, as are the holes on mine (normal is 14mm). I bought an SFC spindle from Wolfgang.
not certain why you want the standard footpeg mount for, love to see you racing with them
attached photo is Keith's work and is the best way to do the modification I believe
agree with the 16mm spindle upgrade
bevelman said:
thanks guys-was worried about jota style rear set availability-will fuck the standard lugs off
have stacks in stock, don't worry, be at least 10 sets there, never counted them
besides we can do a custom set up using the pillion pegs for you so you can lean over further
is only a bit of lathe work, it is supposed to be a race bike isn't it ?
