TCIP4 Advance
Yes standard pickups.
Don't think it is a pickup problem, the Ignitech software say its only advancing 23deg at 4000rpm although the map is set to 31deg. Something in the software seems to be limiting max advance.
AndyW said:
wherever there is inductance & capacitance there is a delay: there's also delays in the amount of time it takes for an LED to fire (some are better than others). This is why the timing appears to retard slightly though progressively on a fully advanced points ignition from about 2000rpm upwards. You only get so much measuring equipment for your money...
I was actually referring to the LED in the strobe unit...
Strobe devices have their limitations too as demonstrated in the case of a points ignition being strobed from 2000rpm (i.e. full auto advance): the spark appears to retard by ~4-5 deg by 8000rpm. Some of that retardation 'error' will be due to induction/capacitance in the bike's ignition system, some of it due to the limitations of the strobe device itself. Best you're going to get is an 'approximate'...
