The small carburettor nipples
LaverdaSoren
Nora Sweden
I am making a couple of carburettor cables with non standard length for Dellorto carburettors. When searching I have only found 3 x 5 mm nipples that
are to be soldered onto the wire but it seems the original nipples are crimped onto the wires.
As I have never had any problems with original carburettor nipples parting from wires I have come to beleive that crimping is the most reliable method.
If I should crimp the nipples, can someone recommend what tool or pliers I should use?
Can nipples made for soldering be crimped, or where can I find nipples made for crimping?
Or are well soldered nipples just as reliable as crimped........?
Soren
Hi Soren
If you want to make or modify " Bowden" cables yourself, you'll need to solder brass nipples to your carbon steel wire.
Its an age old skill and can be done with a large soldering iron and probably many
other ways with plenty of flux ( gas stove).
Make sure you splay the cable end correctly. You can make up barrel or pear nipples if you cant find one in the correct size.
All modern cables are swaged or pressed/ cast so you cant adopt this method at home. Id agree they're probably more reliable but you're not doing clutch or front brake so shouldn't be an issue.
Just watch you dont get solder running into the cable too far, as it will snap if it has to flex and dont overheat the cable.
Ps, i prefer to grip the cable upright so the solder stays in the nipple countersink.
https://share.google/aimode/ohPKQra7wUeUkjPkm
