Rockitdoc
- Fort Collins, Colorado
Time to see if this beast will start. Hooked the fuel up, checked for spark, again, saw spark, and turned her over. Cranks fine, but no explosion noises.
So, I rigged a contraption to get fuel to the beast with the fuel tank removed so I could see the interior of the carbies while cranking the throttle. Should make adjustments easier later, also.
Anyway, fuel is not getting to the interior of the carbs. Removed the brass screw plugs on top the pumps and squirted in some fuel. Fuel ran down into the mouth of the carb and when I cranked her over, explosion-type noises happened
, but no start. Obviously, the fuel pump must need primed to get the fuel from the bowls into the carb interior when the throttle is opened. I've been rooting around the site, the manual and even Google, but can't find the process. All help appreciated.
