martymoose
- Sydney, Australia
Laverda SF said:THE COPPER WASHER!
Doesn't mean you can't re-use copper washers a few times as long you file them flat and parallel and not penned beyond compression.
Does anyone know if the correct thickness and size ones are a readily available item from generic fastener shops? Or do they have to come from Wolfgang et al? I've recycled mine far too many times!sfcpiet said:Best is to simply use new (correct) washers when refitting the head.
Piranha Brother 2 said:Does anyone know if the correct thickness and size ones are a readily available item from generic fastener shops? Or do they have to come from Wolfgang et al? I've recycled mine far too many times!
CLEMTOG said:The original nuts with yellow plastic inserts have been snapped up by rebuilders in the past, does anyone know of a source for new ones?
CLEMTOG said:I have seen at least two 750 engines with replacement stainless "domed" (beehive) nuts and the threads had bottomed in the nuts causing leakage and warpage. The original nuts with yellow plastic inserts have been snapped up by rebuilders in the past, does anyone know of a source for new ones?
I got some from the local diesel injector refurbisher, seems he had a use for the thicker ones as required for the Laverda and kept them in stock.Piranha Brother 2 said:Does anyone know if the correct thickness and size ones are a readily available item from generic fastener shops? Or do they have to come from Wolfgang et al? I've recycled mine far too many times!
3 of the 8 yellow ones on the ex Dave Mintons GTL are white don't no why.
