G
Grant
Guest
Ok, the issue is likely that the stand is tired.
Does it have 2 adjustment bolts and lock nuts? This will allow a small degree of increased clearance for the rear tyre and still maintain stability on the stand.
If you had the wrong stand then it would barely touch the ground if too short and give you a hernia if it was the longer type.
Plus, you never know if some DPO has 'improved' it somehow.
