LaverdaDave
- Toowoomba, Australia
My '76 750SF if fitted with aftermarket Moto Witt EMS. The gremlins got in and loosened the screws that hold the 'grundplatte' in place so the timing got out. I finally realised the problem and have got it running by adjusting the grundplatte to a position that seems to have the engine running smoothly. The documentation suggests the timing can be checked with a strobeoscope; but how does one use a strobe on this type of ignition. The grundplatte does not move!!. An additional issue is that she often fails to spark on first try. It is necessary to place it in gear and rock it a little until it will start. I am assuming this is an indication that the timing is not correct and the EMS will not spark when the cylinder is too far from the correct position.
Any help on how to check and correct the timing with this system would be greatly appreciated.
