Hi Phil, I have a push-pull on my 3C (came off a GS1000), using only the pull wire, though. If in place, both cables are running on the same plane on that twistgrip, so I'd say you can't run them as a twin pull as is. Might work if you glue a steeped washer on, to provide a guide for the second cable, but that will for sure not work with the push-pull switch bodies.
You might try to find a Morini 3 1/2 unit instead, it is twin pull and has starter button and kill switch, much like the ND switches on the later twins and triples.
Regards,
Stefan
