As the point that the original owner was doing a mix of avgas and regular fuel to run with, did he mention what avgas he was using (80/87 or 100LL) or any problems with the lead fouling the plugs, or excessive lead buildup in and around the valves? As the lead was added into aviation gas as the anti-knock agent the amount of lead added was far greater than the automotive side when 100LL (Low Lead) was brought into use. One thing that 100LL does, if used, is foul the plugs and build up deposits of lead inside the head. A lot of older aircraft engines were never designed around the need for the such high compressions that we find in todays high performance engines so we have had to use additives to keep form getting the lead fouling of the plugs, and valves (TCP). The solution was to get an STC (FAA permission slip, so to speak) and start burning MOGAS (car gas). The lower compression engines loved it and only reported issues at higher altitudes. I worked for a FBO when I first got started in aviation that had a flight school (how I got there in the first place) that would have the problem of lead fouling at lower RPM since there was not enough heat to burn it out. The trick (a bad one) was to run the engine at high RPM (above 2000) for a minute or so and then start leaning the engine back until the CHT got high enough to literally burn the lead out. Sometimes it worked, sometimes it didn't, but it sure put a lot of strain on the heads and valves, but then most of our valves that are used today are sodium filled so it is not as bad as what I did running the SF with a 50/50 mix of 100LL and BP 93. When I pulled the heads for the overhaul ('88) years before ethanol was around the only issue I had was the lead buildup using the fuel mix. Switched to a 75/25 mix and Scott Potter did not mention any issues with lead during the most recent overhaul (still completing the complete restoration on the SF) but the engine was never run on any gas that has ethanol in it so I can't say what it will do to the valves. As for the aviation side the issues started with unleaded fuel being the only MOGAS you could find east of Texas. The issue's that started there were higher operating temps, and burned valves when the operators tried to run it like they did before. The one really bad thing that unleaded and now the ethanol has done is corrosion and fuel seal leaks. The materials used originally were designed around fuels without additives, but the crap that is put into car gas eats up the valves and causes the seals to leak (swells like a tick on a hog). If it were pure unleaded it would probably be just like the old days with very little issues, but putting ethanol into an already toxic mixture of cleaners just means that we have to monitor clearances more often, and for me I have a cheap borescope that I can look into the cylinders and see what's going on.
Now, I wish I could have a beer but won't happen till October so ya'll have one for me.
Clay
