Laverdalothar
- Germany
sfcpiet said:In over 30 years of Laverda triple ownership, never have I experienced problems with fuel feed. Taps, hose and carb unions are all up to the job. Never even considered swapping them for something else! Hose routing only has an influence if it is draped OVER the tank...
The Breganze boys got it right from the start.
Hi Piet,
as you know, I had fueling issues which lead to the sized valve on my 1000 SFC (which still needs a fix...
The moment you get below reserve and corner a bit (not hard, just a bit...) the snorkel of fuel tab that is higher (on left corners the right one) is sucking air. that is a fact at least on all my bikes. even going to reserve does not fill the fuel-lines fully anymore, it feels as if the fuel just dribbles into the line. I have tried several different routings, several different pet-cocks, made sure they are not blocked or water is the tank etc. - I had it always and ever. I had it with Dell'Ortos, I had it with Keihins - no difference.
The only way to avoid it is to keep the tank full.
To the theory of the fuel stays at the ground even in corners: I understand the point of centrifugal forces, but they are not applying the moment you enter the corner, they are only applying full at the center of the corner, increasing on the way from entering the corner to the center and decreasing from the center to the exit. Fuel still can move a bit on the way there and out. I can not suggest to look at the fuel lines while cornering, but I had those issue several times, believe it or not.
Oh- and lets not forget the situation when you brake hard and all the fuel splashes to the front of the tank or up- or down-hill rides with limited fuel in the tank. Maybe I am doing something wrong here, I don't know, but it happens on all my bike except for the 750 Formula maybe...
