Vapor Blasting 1st impressions
This is Hi-Pressure water 1500psi+(basically a mechanical fuel injector) with siphon media in a cage. NOT 150psi  AIR supply.
Are we not on topic to describe the label as a Vaporizer and all you need is a Cage to contain debre.
The nozzle is very important on what you want to clean.
Personally I would NOT give a damn if I siphoned Glass bead, Quartz or Sand with that Hi-Pressure pump providing you get results and $2000 is away outta my range when one can build a bigger cage with 10 time the capacity for 1/3rd the price.
150psi of air will siphon liquid media providing you have a minimum of a 3 Hp compressor. A 5 Hp Air compressor is a take over a 2000psi water pump but more expensive.
Consider your needs or both and the your shop.
And you Wife - LOL
The media is fed from the hopper via a slurry pump through the hose / nozzle, its is not siphoned, air is added at the nozzle.
If you read the literature on-line for Vapor Honing Technologies they explain it pretty well.
What's a Vaporizer?
Ok  - A Slurry Pump with 130 PSI Air at the nozzle - Now I understand.
I'm kinda of an old Air Siphon glass media guy when it comes to Aluminum and hit it lightly.
