"I don't know where I come in the parameters of very fast or very fat Paul, probably somewhere in the middle! Grin Grin Grin"
Hey Bob, of course 'fast' applies to you. I know for sure, because I overheard it said in the pits at Mallory...
Bystander... "Who's that fast bastard on the V6"
Piero... "Oh, that's Bob Dixon"
Anyway, I like the teflon coated Alu pistons a lot, huge weight saving as you say, which can only be a good thing for reducing momentum for the numerous movements that front suspension and steering have to accomplish.
Having said that Alu has 4/5/6/7 times the thermal conductivity of steel (depending on the alloys), so, in therory, will tranfer the pad heat to the fluid to a greater and faster extent. I guess the teflon coating has an insulating effect, but will be so thin as to make little difference I suspect.
The lower mass of the Alu piston will also allow them to be knocked-back [into the caliper] easier. As you know piston knock back [driven by tiny amounts of disc wobble] is essential to disc brakes, as it provides the running cleanace at the pad/disc when the brake is not applied. The low friction teflon coating is intended to help here. Lack of knock-back causes drag and thus heat build up.
Hag.
