Grant said:It's the kill relay from a CDI triple.
It appears in the appropriate wiring diagram for that model.
dja981 said:Grant said:It's the kill relay from a CDI triple.
Didn't the 74 triple have a different type of stop relay?
Dave
Grant said:If you remove the kill relay you can't stop the motor unless you stall it.
That's risky if you fall off and it's revving it's guts out on it's side.
Not sure if it also means it can be easily started though.
Rusty Spokes said:I heard the early 3c had no relay..I read that the bikes were easy to steal. They could be bump started with no key. Don't know if that is true or not.
