kneeslider
Hi there all,
I managed to get my RGS through it's MOT test last week, so the day after, I set out on my first long ride, however after only about 50 miles, the handlebars began to shake about, and all of the symptoms of a puncture were apparent. Looking down, the front tyre seemed to be inflated to the correct pressure, so something else would have to be the cause.
Anyway, I rode slowly home about 15 miles, anything over 35mph produced wobbling, so it took a while. I discovered on stripping the front down that the speedo drive side bearing had collapsed almost completely!!
I bought some new bearings, and installed them today, after first measuring everything to ensure that the middle spacer wasn't too short or long, then tried fitting the spindle through the middle. It turns out that the spindle is very tight, and it appears that the new bearings haven't aligned properly in the holes!!
I have fitted lots of bearings in the past, but none has ever done this!
The shims under the bearings were re installed, but I suspect something amiss here. The bearings seemed to be quite a loose fit in the bores, and tapped home with a satisfying sounding clonk when the bearing hit the bottom of the bore.
Perhaps I should have ordered some new shims to fit under the bearings?
I sense a battle coming up to get the old ones out now I put them in with a smear of Locktite.
Has anyone encountered this issue?
Any advice, or suggestions?
