Where to get valve shims?
mar
California USA
I am having the valves adjusted on my 82 mirage. I seem to recall from some years back that alfa romero shims were the same. In looking here on the search function i see that Keith said Renault/Citroen shims are the same.
I know I can probablly get them from Wolfgang if I tell him the sizes I need. I was hoping to find someone local that can offer them as needed rather than having to get them shipped.
What is the common practice? Or does everone just have a large box of assorted shims? :D
Thanks, Myke
Mar , you could get the existing shims ground back as long as they are within spec ! 1.3mm @ a minimum
if my memory serves me right  :-\
Bit of wet n dry, a few cans , quality time in the shed with the radio on  ;)
Or drop em down to ya nearest machining shop.
All the best , Hooksey
I got a set of shims from a fellow Laverdist. He's got a lathe and good quality steel. They are quite easy to make, I reckon?
Rufustbear said:
Yes easy to make but dont forget to temper them .
Yes, I will heat them up to over 600? Celsius and drop to oil? With this set of 10 shims I have a reserve till the end of days.
