Wiring harness routing on a 77 3CL
rogerd
Does anyone have a picture of the correct way to route the wiring harness at the rear of the frame spine in the airbox area. it one bit I don't have a photo of.
It's a CDI version so it can't route under the frame and above the airbox as the airbox bracket is in the way.
Thanks in advance.
Do these help?
Thanks
I was not sure if it needed to go over the frame or above the starter relay and under the frame. It looks like the later - it squeezes through between the starter relay
and the frame.
