Simonr501
- Lympne, Kent. UK
I thought I would pass on some 'learning' regarding the Witt DMC2 optical trigger (fitted to series II triples only apparently).
I had a problem with the Jota 120. When the engine was good and hot the engine seemed to peter out and stop (I thought I was out of fuel), which progressed to cutting out as if the kill switch had been flicked.
I was stranded by the side of the road, but after a rest the engine would run for a while.
I tried all sorts of things, including pulling at the wiring with the Witt in test mode (0) and the plugs resting on the cam cover sparking away nicely. I didn't identify any loose connections, bad wiring or anything suspicious. The sparks stopped when putting a card in front of the lens - so everything normal.
However, it seems the culprit was the optical trigger! (thanks for the suggestions and help from Keith N and Reggie).
I cleaned the lens with a (carefully squashed) cotton bud and no failure after a few hours today.
It seems the optical sensors do not perform so well at high temperature, some units never ever fail and others suffer. With a clean lens obviously the performance can improve.
See: http://www.laverdaforum.com/forum/index.php?topic=87238.0
and notably John (Wilson?) IIS's contribution on: http://www.laverdaforum.com/forum/index.php?topic=85643.0
