1200ts
- USA - California
I there any good fix for the front sprocket being loose on the splines? Other than taking the gearbox apart and fitting a new gear?
I have heard this problem only happens when fitting pattern sprockets rather than factory ones. Well as there are most likely no factory sprockets left what can be done the prevent a recurrence? I have seen Laverda's where the sprocket is almost impossible to get on and also to where it just falls on. What was the factory specification for the spline clearance?
Bruce
Bruce
