you must troque the joint up to the correct valve this depends on the flange size eg 6" 600# will be marked on the drawing and this will be logged in the broken joint register and so on. But in the uk you can't just flog it up to whatever you think is tight because you must sign to say you have done the joint up to the valve in the register and now i'm going for a little lie down
