cape’s bar end weights with cruise control
cape
Finland
If you suffer from numbness of hands on long journeys, here’s one solution.
Bar end weights to fit 22mm handlebar,
with 16mm minimum internal diameter.
Including knurled nut for cruise control.
Cruise control is operated simply by turning the nut to lock the throttle position.
The thread is left handed, so the nut tightens against handlebar grip if turned while increasing throttle.
Easily unlocked by turning throttle to off direction.
Machined from 304 grade stainless steel, ~500g/pair.
Note! 6mm Allen bolts + counter parts for fixing not included.
Limited edition!
The first couple of pictures are showing the prototype on my Jota’s handlebars. The rest are 3D illustrations just for extra info/what to expect.
To sum up. Custom made bar end weights, solid stainless steel construction (should last a lifetime), decent weight to prevent vibrations and cruise control so you can rest/shake your throttle hand when needed.
Ciao,
Sami
cape
Finland
cape’s bar end weights with cruise control are now available.
price 59€+shipping.
Ciao,
Sami
