Charge coil wanted
davidsmirage
There is a coil on eBay at the moment item number: 203492514338
Not sure if it's the one you're after or not but you could check it out.
HTH David
Dellortoman
HTH David
Nope. Wrong coil. It's one of the redundant coils that normally gets chucked away when upgrading the ignition.
The seller is pretty optimistic in thinking it's worth something.
I hope nobody is misled into buying it as an alternator coil.
