Mikuni RS 36 float bowl levels (again)
Paul LeClair
Administrator
Staff member
Hi all
putting the RGS back together for another dyno session.
very very carefully set the float levels at exactly 17 mm, using digital caliper.
put the carbs back on the bike tonight, hooked up the fuel lines, and took yet another gasoline bath......
fuel pouring out the float overflow tubes.
using a level and degree wheel, measuring from the top edge of the float bowl, the effective angle of the carbs is 32 degrees, using stock metal intake stubs and rubber couplers. My experiments with curved intake manifolds failed for lack of a suitable material, so far.
I can't be the only one experiencing this persistent problem of overflowing float bowls, or if I am am, what the heck is everyone else doing differently than I am???
to stop the overflowing, I have to set the floats at roughly 20 mm, risking jetting issues and dry float bowls on extended high speed running. Any suggestions gratefully accepted.
Paul LeClair
Where does the number 17mm for the float height come from?
Before setting the fuel level you first need to confirm that the plastic tip of the float valve needle is in good condition.  Over time the tip of the needle wears, doesn?t seat properly and alters the fuel level. That?s normally why your fuel level is out of whack. To get at the needle you first need to remove the float?s pivot pin. Before you do take a look at the carb open in front of you. There aren?t a lot of parts there but they need to be reassembled the same way they came out. You see the metal tang just in front on the pivot? That?s where you?re going to make your adjustment. Also note that there is a small metal clip that attaches the needle to the metal tang. Be gentle removing the floats so you don?t damage it. OK, remove the pivot pin and then the floats. Pull the needle from it seat and have a look at the tip. It should be smooth with out any deformation, grooves, scratches etc. If there are replace it with a new one. Now that you have inspected the needle you can reassemble it all again but don?t reinstall the float bowl.
With the carb upside down, tilt the carb until the tang on the float just makes contact with the needle rod protruding from the float valve. At this point the distance between the bottom of the float and the float bowl mating surface should be 16mm ? 1mm or 0.63" ? 0.08". Remember the carb is upside down so the bottom of the float is facing you. If the distance is out side of this range gently bend the tang and recheck. Ideally you would reassemble the carb and recheck it with the fuel level gauge. If you don?t have a gauge you?ll have to trust you set the height properly.
Measure the distance between the bottom of the float  and the float bowl mating surface (#1). The distance should equal 16 mm +/- 1 mm or .63" +/- 0.08
Hi Paul, I admit that I always wondered about your carb problems (overflow, jetting, etc...). Never had this kind of problem on my RS36s, never had a single drop flowing out of them. I just had to limit the duration of the pump to solve a tendency to empty the float bowls in some extreme cases, that was all... I just stuck on Red's setting (apart the jets), just checking that the float levels before fitting the carbs, they were perfect so I didn't touch anything. Since the beginning I just wonder what happens on your engine. I don't think it is related to the angle of the carbs (mine are exactly like yours) and 3mm (17 to 20) is really a huge (and hazardous) difference in terms of float level... I'm sure that you have checked everything already, however as you got the parts through Ebay I thionk, are you sure that you have the correct float (shape, weight,...)? Did you check also the float axle (I had once such a problem on a Dell'Orto, the axle was slightly bent and the float didn't move freely -although no problem to move it by hand-)? Very sorry, this is not a great help, not easy to "see" the problem at distance but I'm more and more thinking that something is wrong on your carbs.
Even the test on the dyno couldn't be of great help, just saying that you loose some hp due to float level issue, but it doesn't tell you in what proportions, above all when the bike is not in perfect vertical position like on the dyno...
jlo
jlo
Paul this must be very annoying, stating the obvious but maybe try lowering the carbs into a clear container full of fuel and checking the floats actually float in situ,with the bowls off.Thats going to tell you they float and there is no impediment to them moving on the pins,when the reasonable wont help start looking at stupid stuff.
Hi all
carbs back off on the bike, on the bench, split from the linkages, choke rod, etc, and totally dis-assembled to bare bodies, each of which I am running through the ultrasoinc one body at a time today.
the float valves are new 2.8's sourced a few months ago, and the o ring on the float valve body looks OK, but I am going to replace them anyway. The float needles were new with the float valves a couple of months ago, but I will measure them and examine them with a magnifying glass anyway. I am going to replace the O rings on the fuel connectors between the carbs, just because I happen to have them off and ready to hand, not that they have anything to do with my fuel bowl overflow issues
The floats themselves are presently all "floating" in a large glass jar of gasoline, and all seem to be "floating" equally. I am going to leave them there until I put the carbs back together tomorrow, see if any sink......
open to any other suggestions while the carbs are totally disassembled....
Paul LeClair
an update...
carbs fresh out of the ultrasonic, no drama on reassembly other than the small (tiny) spring and ball bearing for the choke rod going walkabout briefly on my dirty garage floor, solved by sweeping the floor with three very high strength magnets......  :-[
with carbs reassembled except for float bowls, and float height set by measurement at 17 mm, hooked the carbs up to fuel, and compressed the floats by hand.....which did not fully stop fuel flow. :-[
on very close examination, it became apparent that the "tongue" on the float that is to press on the spring loaded pin of the end of the float needle, was extending far enough that it was also contacting the round edge of the float valve, preventing the needle from fully sealing.  :-[
so, pull the floats, measure everything, and I cut back the "tongue" by enough to clear the edge of the float valve, so it was not overhanging the edge of the float valve. In this case, I had to cut a fairly large amount off the tongue, roughly 2.6 mm, essentially half it's length..... ???
floats are set at exactly 17 mm, carbs are back on the bike and hooked up to fuel , have been for about two hours now, no fuel overflow, so far.... :-\
if the solution to the problem is as simple as trimming back the tongue on the float, then I wish I had figured this out quite a while ago!!!!
seem to be stock floats, I know the float valve is stock and seated properly, can't figure out why I appear to be the only one having this persisten problem.
can't fire up the bike just yet, have the Howdi Engineering starter clutch off the bike for a bit more shaft shimming, and some rewiring to complete to the new (used) TEK KP 03 coils, going to try the voltmeter experiment to determine coil polarity, then hope to have the bike running maybe later today yet.
Paul LeClair
This is very good news Paul! Not only you found the cause of the overflow but also you probably solved the whole problem on this set of carbs, meaning that everything will work correctly now and that very probably you won't even need a set of angled stubs... ;)
Of course, some re-jetting will be necessary but it will be easier to do now.
Why this problem with these floats? Don't know really but if I compare with the usual problems with Dell'Ortos (or even Weber automotive carbs), there are sometimes some very slightly difference form a batch to another and some internal parts are slightly different. Another possibility (very usual with Dell'Ortos!) could be some aftermarket parts (sometimes counterfacts), manufactured in South-East Asia or in Eastern Europe, very poor quality and sometimes wrong shape.
No matter what is the real cause, the most important is that your set is working correctly now and I have no doubt that your bike will do also (except if your set still has some other wrong parts in it! ;)
jlo
Bike is all back together and running, running very well.
I made a large number of changes all at once. 54 mm i.d. large stainless steel silencers from Wolfgang, valve clearances set looser at .25 mm intake, .30 mm exhaust, TEK KP 03 coils with new NGK plug caps and new copper core plug wires, carbs totally disassembled and run through the ultrasonic, as well as the float tabs trimmed 2.6 mm, better venting (again) for the fuel tank, etc., etc.
I will phone the dyno place this week and book another session. Was out practicing first and second gear wheelies late this afternoon, did I mention the bike seems to be running REALLY well.....  :D
Paul LeClair
Hi Paul,
So now you have it going I take it you may not want a set of angled stubs anymore.?
Only one set done so far, 36mm bore, am getting some made tapered 36 to 32mm.
Managed to get 10 degrees, should make some difference.
Came up great.
Just need to try them out now and let you all know the result.
Tchau
Red
Hi Red
please keep me on the list for two complete sets of angled inlet stubs, one set 36 mm for the 36 mm Mikuni RS flat slides and ported head on the RGS, one set 36mm tapered to 32 mm for my 79 1200.
Paul LeClair
Well we bolted the angled stubs up to an RGA yesterday and slotted in a set of Carbs.
Everything looks fine, lines up a lot better especially the airbox inlets.
Still run out of room though, be bloody difficult to use the original airbox rubbers, length will be an issue.
Though you could have them slip into the airbox itself a fair bit possibly.
Will work fine with K&N Pods though.
So have placed an order for 36 stubs, 18 with 36mm bores, 18 with tapered 32 to 36 mm bores.
Paul, will have this set in the mail to you tomorrow.
Tchau
Red
