Brembo master cylinder rebuild
Laverdalothar
Germany
you may add the "how to overhaul brake and caliper masters" PDF from me if you like...  ;)
http://laverdaforum.com/gallery/albums/userpics/11278/Repair_Guide_Clutch_and_Brake_Master.pdf
noodels
Hi thanks for the How To/hints. Q does this method apply to rear master repair laverda 500 ?
thanks in advance  ;)
D
Davo
Guest
There is an excellent section on Brembo brakes in the book "Guzziology" by Dave Richardson. Covers all aspects of servicing and rebuilding calipers and mastercylinders as well as compatibility charts for brake upgrades.
Obviously copyright so you would have to buy a copy.
Spyder31
Dublin
That was really useful, many thanks for sharing it
Laverdalothar
Germany
thanks for the feedback, glad if it helped. It is a fairly easy overhaul (well - if I can do it, almost everyone can), maybe easier than most people think.
Legs
Adelaide Hills
Thanks Lothar,
I believe you have posted this before; got the instructions up in the shed and used them when I rebuilt my m/c years ago.
Laverdalothar
Germany
Mactriple said:
Thanks for that. How do you get the plastic reservoir off if it won't move?
Ian
if you have removed the screws and the metal plate, it should come off with a bit of gentle force. Not to much, please. All it holds in place is just maybe some mud
Dellortoman
That bloody mud in the hydraulic fluid is a bit of a mystery to me. I dunno where it comes from, but it seems to contaminate all hydraulic systems after a few years. Brake and clutch hydraulic systems are closed, so I very much doubt it's dust that gets in from outside. It doesn't appear to be metallic so it's not from cylinder wear. It must be some chemical change in the fluid that causes particles to precipitate.  Are there any clever people out there who know the answer?
Laverdalothar
Germany
I suppose it is a mixture of water and wear. The piston f.e. has a coating, maybe that wears off a bit and builds up that mud together with some water (Any time you open the reservoir to top-up the fluid, it comes in contact with air and might drag some humidity out of the air into the system)
Laverdalothar
Germany
Mactriple said:
Lothar,
It was mud. A couple of sessions in the ultrasonic cleaner loosened it up nicely. Thanks.
Ian
(cheers)
great it worked out to be just mud and now you can re-assemble the sucker again. Be careful after re-building it, make sure it really holds together and is tight and sealed correctly. Better test the brake with slowly riding several times and check the fluid reservoir stays full.
CLEMTOG
surely its the degradation of the black seals?
I notice on TOG that the fluid is nice and clear in the (see through Ducati) master cylinders, but that it changes to dark then black over about three years, by which time the fluid should be changed anyway., Seals maybe after six years, leaking or not, we all do that don't we?
Mactriple
Laverdalothar said:
(cheers)
I will get the parts re-anodised and go from there. is the o-ring a special one?
ian
