Brembo master cylinder rebuild
I don't think they are made of a special material, but they are special shaped. So - no chance to have them replaced by something "standard". You will always need to replace the complete piston set. But then - how often do you do that...? Every 30 years is a good interval I would say...  ;)
Thanks Lothar the instructions were very helpful. Just finished both M/Cs from the 860cc MV Agusta Monza. Worked out very well thanks. The most expensive part was getting both bores re-sleeved due to corrosion. Cheers
Ian
