laverda mirage green
feelerguage
noticed on an earlier post
grant had repainted a green mirage
could anyone telll me where i can get this paint either code or supplier
thanks
My painter matched an original Mirage green sidepanel, but his paint codes are his own IP and he will not share them. Bugger.
In any case, the shade is close, but these days you don't get the correct large size of metalflake to give it the final sparkle.
I am sure if you invest in a paint gun with the correct sized jet and buy the flake separately it would work, but any I have seen painted professionally always have a flake size that is too small.
Whereabouts in the world are you?
Grant,
I had the same metalflake issue with the SFC1000 gold; even with the largest metalflake that the spray firm (Altamura) could provide, the metallic effect is only really obvious in bright sunlight.  Apparently, the car industry wanted smaller flakes, so that dictated supply.  I guess that if I had had the time, I may have been able to source larger flakes from somewhere myself - however, I did not.  At least now all the gold is the same shade and the metallic grade, as the original gold was a really patchwork; the wheels, fork sliders, yokes and frame where all different.
Cheers, Andy
This has been covered in some detail in the past. The original green paint is very difficult to match and it's certainly not something you're average automotive paint supplier can make up. Pete Priest [ www.priestbikepaint.co.uk ]has done a nice job on a green mirage quite recently . He can paint it for you but, like Grant's man, is a bit cagey about what the make up of the paint is. It's a great colour but there's definitely more to it than meets the eye!
"Case study"??
now there is a painter who is taking himself way too seriously.. or hasn't been wearing his respirator...
custom guys do the large metal flake here Grant my guy in Bromsgrove does it.
LJ
I'll pass your comment on Don, Pete will find it extremely amusing :D :D He's got one or two humourous observations of his own about people who waste their life spend time on motorcycle forums, myself included! :D :D :D
thanks
You could just stick some John Deere paint on it. Probably pretty close to the original.  ;)
Just go to your sprayers colour charts and select the pea green you like.Simple peeps.
LJ
just made me think of sanitation engineer....
