markQLD
- QLD Australia
yes, i am a curious sort of soul. & i 'want' to know. & yes, i really don't 'need' to know.
torque & rpm. yes please !! (thumbup)
it's been in my blood since i first cut me teeth, up in da cane fields.
so i reckon it was time to have a dedicated dyno topic.
no, i don't want to turn this into a pissing competition, but i am interested in all dyno curves.
the good, the bad, and the ugly!
so today, i did a 2nd dyno run with Clyde, after we nicked the exhaust system off Miss J. no, we won't go there. :-[
but i 'wanted' to know the comparison, between the Laverda Corse 3-1 (red line), and the 'standard' factory Jota 3-1-2 system (blue line).
and this is it. which is a little different to what i expected. 'cause i thought, maybe more up top above 7,5000 rpm? but wasn't much.
the big variation was in the 5,500 to 6,500 rpm zone.
the only thing that was changed was the exhaust. (and it was a different day)
note: today, the rpm sensor was picking up some interference. the rpm dips down and the torque rockets up.
bit of a bugga. so i got Fred to add the rpm data, below the power and torque data.
no, unfortunately Clyde does not pull 194 ft-lbs.
but i'm thinking that's probably just as well ay!
& this is my reply from a couple of weeks ago, that started a good bit of hijacking. (hence this topic)
http://www.laverdaforum.com/forum/index.php/topic,91579.msg306919.html#msg306919
so,, be forewarned you dyno blokes.
as i've been a forum searching and will soon start to throw up a link to previous replies with actual dyno results.
cheers, Mark
cheers, Mark
