Laverda specialist in the USA
I second Jim' suggestion to call Wolfgang for advice on a crank rebuilder in North America.
Several years ago, on Wolfgang's advice, after I experienced a very bent stock rod on my RGS, I sent the crank from my 84 RGS to https://www.mongoosemachine.com/ Wolfgang supplied them with new crank bearings, a full set of Carillo rods, and all the specifications. I was happy with the results.
I would still check with Wolfgang for current recommendations, shops and staff change over the years, I do not know if he still uses Mongoose currently.
I am pretty sure I still have the two remaining original RGS rods in storage somewhere, that motor only had 3,000 original miles on it when the fuel taps failed and the motor hydrolocked when I tried to start it not knowing the cylinders were full of fuel.
Paul LeClair
Paul LeClair
Thank you Paul ..... I couldn't remember the name of the company but I know people who use Mongoose and they do top notch work. There is also Colt Cams near Langley that does twin cams (through Wolfgang) and he is interested in having a go at triple cams so when I get a chance to get the head off the FM he wants to see a set of triple cams.
Jim
