Laverda SF
From my experience a Heel/Toe Shifter don't shift like that. It's different where you have to lift your foot off the peg and use your heel to shift up - Really no big deal but you have to learn and get accustom to it.
For starters the SF is a short motorcycle and I have long legs, weighed only 138 lbs at 5'11" with a 9 1/2" foot. The original center peg location was uncomfortable for me so I relocated the shifter and rear brake pedals rearward mounted on the Passenger sanctions. I did keep the original center pegs as they were very useful when diving deep into Hi-Speed corners to keep the bike balanced - Plus they served as a crash guard.
Sometimes, if you where not positive, I would get a false neutral shifting into 5th but it's a common Breganzie issue.
Even the Triangle location was too cramped for me when touring my SF. I found it rather easy and fast to either shift and brake where I mounted the levers.
I'm rather proud of that Spring Loaded Shifter Lever design - Same with my rear Mechanical Lever Pedal for the Super Ferino Rear Drums. Mainly because it looks Classic and will keep your body off the ground.
I kept the original Honda bars but twisted then a few degrees lower and welded in darts to prevent the bars from slapping the tank.
Heaven forbid for denting that Tank. A Breganzie would sooner fall over just looking at her and always dent the tank if you used the side stand.
"Can you Rock a Heel/Toe Shifter keeping your foot centered on the Peg" - NO you CAN'T - Just how flexible is your ankle - You always have to lift your foot off the peg to up shift with your heel - Perhaps if you have a 12" foot you could ;o)
