martymoose
- Sydney, Australia
You want to ride an 81 jota in the city?
I fitted a set of Mikunis to the Flying Kangaroo 1200. For me the difference was magic - the mid-range pulls like a train; I have been gibbering on about how much I appreciate them ever since.
36 PHF = correct34mm? Im running 36 dellortos on the sf2
Yes they will. A 25-30% improvement in fuel consumption demonstrates decent carburation across the rev range. Makes no difference to max power. Only downside (apart from cost!) I've found is difficult cold starting on choke...it needs just a bit. Not too much and not too little. Bit like Goldilocks.I,m considering the same change ... fitting mikunis to my 180 Jota. Reading all the above still hasnt convinced me either way. For me the dellortos are fine at highway speeds but way too rich for city work and idle. Can anyone confirm the mikunis clean up fuelling at low revs. Thanks
Maybe I shouldn't have used that Penrite 25w60 Endro oil in Winter
Yes, the Mikuni RS is the better carb, but more through virtue of age than design.
