Crikey Cam, the Viton sheet is cheap enough but the postage to Australia, and import duty, add a whole lot more to the price!You don't necessarily have to replace the choke plungers if they're not sealing properly. Have a look at the little rubber seal on the tip. If it has a groove worn into it from the fuel aperture seat, hook the little ribber disk out with a pointed tool, flip it over and push it back in so the unused face is now doing the sealing. If you've already done that and both sides of the rubber seal are worn out, or it has gone hard, you can replace the rubber tip without having to buy a whole new brass plunger. Grab a small piece of 2mm thick viton sheet and a hole punch (6mm I think, but could be 5mm - memory is a bit hazy) and you can punch out as many little sealing disks as you need. Just flip the old ones out of the choke plungers and pop the new ones in. I dunno why Dellorto carb rebuild kits don't come with a new choke rubber. They have a bunch of other rubber O-rings and stuff in them.
Viton sheet is available on ebay: https://www.ebay.com.au/itm/114571495690?hash=item1aacfe490a:g:LX0AAOSwU9xUSMC3
Cheers,
bazzee
