piranha-bro2
- Melbourne
Indeed. Now, to be honest ...I modified that because opening the clamps directly on the inside of the panel or on the airbox is a job for a gynecologist or internist![]()
Quentin,Thinking of removing the middle rows of teeth on both these items - is there a secret method? Cast iron clutch sprocket is easy (but messy) and carbide lathe tools won't like those intermittent teeth whacking the shaez out of them. Primary teeth are hard as - can only think mounting the angle grinder on the tool post as an option (when you don't have Red up the road).
AwesomeCool rig! Sasha RGS breaks out of the shed after sitting still for 22 years!
That's enough fixing things, let's ride now! Lockdown ends in 8 days......
Veeery interesting, Piet. I have been wondering about that - I know that trying to centre the drum on the indexing tool for drilling was not easy, as the dial gauge was all over the place. I'll have to see if I can mount the drum in my little Emco. At least it spins at something like half crank speed.Quentin,
The clutch basket benefits far more from balancing than lightening, I think I had to find about 20gr. to remove in my triple basket. Started by machining the outsides straight and even, not much left to do after that. Stuff a rag into the inside to keep it from vibrating.
View attachment 59186View attachment 59187
Yep.Veeery interesting, Piet. I have been wondering about that - I know that trying to centre the drum on the indexing tool for drilling was not easy, as the dial gauge was all over the place. I'll have to see if I can mount the drum in my little Emco. At least it spins at something like half crank speed.
'is that your works motor in the pic?? No primary chain tensioner thread whatsoever and that double slipper setup. Amazing. I like the drilled oil pump driven gear - less weight there means less backlash. I'll see if my 8mm carbide bit can trouble mine.
The Iwis double row seem to be the go these days (very nice looking chains) - but that's the prob with machining off a row; once you do it, there's no chance to use alternatives - either 2 x singles or 1 x duplex - no more triplex. I'm tossing up whether to machine one row off ... or not.I went with 8 holes in my primary - apart from shedding a few grammes, they sure are useful for rigging up a simple holding tool for the Jesus nut. Obviously I went for twin simplex chains...
No. The duplex does. Only the very last RGS/1000SFC had narrow-spaced teeth rows, especially for 2 single chains.Quentin,
do two single chains fit directly adjacent rows of teeth? IIRC, the middle row was left free with single chains set-up, or later models had two narrower rows of teeth.
But you are right in the point that once you have removed the third row of teeth by machine, you have no other choice than the duplex.
Cheers,
Jo
Worried now.The Iwis double row seem to be the go these days (very nice looking chains) - but that's the prob with machining off a row; once you do it, there's no chance to use alternatives - either 2 x singles or 1 x duplex - no more triplex. I'm tossing up whether to machine one row off ... or not.
I spent a few hours setting up the clutch drum for machining and I can see why they are out of balance - took quite a bit off the heavy side before I got a clean cut right across the outer on the two different sections. Initially on max RPM the vibes were bad - after machining, nice and smooth - haven't got a balance facility - good enough now for half (or less) than crank speed; not sure of the primary ratio - and too lazy to check.
