CLEMTOG
cotton like fluff around the oil strainer rock catcher in the sump, causing an oil circulation problem. The RGS and 120 Jota have a finer mesh than 180's, so is more prone to this (rare) phenomena
the cause of which is an oil change and changing brands as well, no one knows which brands are OK and compatible with others, and which brands follow on and create this fluff. If in doubt or changing oil brands, do only 100 miles on the new stuff and do the (very tedious) exhaust off and remove strainer to check, plus a second jug of your new chosen oil, if you see any fluff, then you have to do this again after the next 100 miles and continue until it stops, usually the second one does it, I have only known three bikes to be thus affected in 45 years, maybe this is the fourth.
