BlackJota
- Sunshine Coast Australia
Both bikes have always had their charging systems working fine. 13.5 ish volts reading when running, on both the on board digital Volt meter and or a multi meter.
The volt meters are on a switched circuit and read 12.8V ish when turning on the ignition. Happy to see that each time. The bikes are always kept on a battery tender in the shed, they are not my daily ride. Always fully charged. It seems there will be dud batteries out there and nothing will stop a dud battery from dropping a cell if it wants to. Looks like when it happens you are stranded. Only another battery or roadside assist or wife with van can get you home again.
The only reason for the onboard Volt Meters is to is to monitor the general condition of the charging/battery system in real time. Just a glance every now and then is reassuring to me. as is the volts reading when turning on the ignition. I will be using the replacement batteries and hoping for the best. No point in changing battery brands and still hoping for the best.
